All Elements in Network
Hi all,
My end goal is to obtain all unique networks of systems within a project. MEPover has a node Elements in connected network which will find all elements connected to the input element. To get all unique networks, you would need to insert an individual element from each network. (If you know of a way or a node that does this feel free to stop reading and I would love to hear it)
I am trying to modify Elements in connected network from the MEPover package to take a list of all duct elements in the project. The supplied list will contain elements found in the same network, because of this, I am trying to remove all elements from the supplied list as they are found in the network of a previous element.
My python skills still lack a little but I was able to get this to work on a sample script.
elmlist = IN[0]
listout = IN[1]
id1 = []
for i in elmlist:
	id1.append(i.Id)
breakcounter = 0
while len(elmlist) > 0:
	id2 = []
	for i in listout:
		for y in i:
			id2.append(y.Id)
	for e, d in zip (elmlist[:],id1):
		if d in id2:
			elmlist.remove(e)
			id1.remove(d)
	breakcounter += 1
	if breakcounter == 4:
		break
OUT = elmlist
The problem:
The elements are not being removed from my input list like they are in my sample. Essentially I want to take the first item and get all of its connections. I then want to remove all of the connections (this list includes the starting element) from the input list and start over until there are no elements left in the input list.
My additions are running with no errors but it is stuck in an endless loop (if not broken after a forced 4 loops for safety precaution as I am working on it)
elmlist = IN[0]
bool = IN[1]
fullList = []
breakcounter = 0
id1 = []
for i in elmlist:
	id1.append(i.Id)
	firstelm = []
	firstelm.append(elmlist[0])
	if isinstance(firstelm,list):
		connector = UnwrapElement(firstelm)
		toggle = 0
		connector = [UnwrapElement(firstelm)]
		toggle = 1
	listout = []
	if bool:
		for x in connector:
			lookup = collections.OrderedDict()
			collectorWithOwner(x)
			listout.append(lookup.Values)
		for x in connector:
			if x.GetType() == Connector:
				ownerId = x.Owner.Id
				ownerId = x.Id
			collector(x)
	orlist = []
	if toggle:
		orlist = lookup.Values
		orlist = listout
	id2 = []
	for i in orlist:
		for y in i:
			id2.append(y.Id)
		if d in id2:
			elmlist.remove(e)
			id1.remove(d)
	fullList.append(orlist)
	breakcounter += 1
		break
OUT = fullList
Here is the original code pulled from MEPover for reference.
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
clr.AddReference("RevitAPI")
import collections
if isinstance(IN[0],list):
	connector = UnwrapElement(IN[0])
	toggle = 0
	connector = [UnwrapElement(IN[0])]
	toggle = 1
bool = IN[1]
def nextElements(elem):
	listout = []
	if elem.GetType() == Connector:
		conn = elem
		for c in conn.AllRefs:
			if c.Owner.Id.Equals(elem.Owner.Id):
				continue
			elif isinstance(c.Owner,MEPSystem):
				continue
				newelem = c.Owner
			listout.append(newelem)
		return listout
	try:
		connectors = elem.ConnectorManager.Connectors
	except:
		connectors = elem.MEPModel.ConnectorManager.Connectors
	for conn in connectors:
			if c.Owner.Id.Equals(elem.Id):
				continue
				continue
			elif c.Owner.Id.Equals(ownerId):
				continue
				newelem = c.Owner
	return listout
def nextElementsWithOwner(elem):
	listout = []
		conn = elem
				continue
				continue
				newelem = c.Owner
		return listout
	try:
	except:
				continue
				continue
				newelem = c.Owner
	return listout
def collector(elem):
	cont = 0
	elements = nextElements(elem)
	for x in elements:
		if x.Id in lookup:
			cont += 1
			item = doc.GetElement(x.Id)
			lookup[x.Id] = item
			collector(x)
	if cont == len(elements):
		return elem
def collectorWithOwner(elem):
	cont = 0
	elements = nextElementsWithOwner(elem)
	for x in elements:
		if x.Id in lookup:
			cont += 1
			lookup[x.Id] = item
		return elem
listout = []
if bool:
	for x in connector:
	for x in connector:
			ownerId = x.Id
		collector(x)
if toggle:
	OUT = lookup.Values
	OUT = listout
Thank you for any help that you can provide.
Steven
@Steven,
look into Genuis Loci package. It contains a lot of MEP nodes.
Hello @Steven
try this
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def getAllElementsInSystem(system):
	a = list(x.Elements)
	b = [x.BaseEquipment] if x.BaseEquipment is not None else []
	c = list(system.PipingNetwork) if hasattr(system, 'PipingNetwork') else []
	d = list(system.DuctNetwork) if hasattr(system, 'DuctNetwork') else []
	return a + b + c + d
mepSystemSet = FilteredElementCollector(doc).OfClass(MEPSystem).WhereElementIsNotElementType()
OUT = [[x, getAllElementsInSystem(x)] for x in mepSystemSet]
