All Elements in Active View not fuction as it's label?
Modifying my inputs on a few scripts we use over to an input of “All Elements in Active View”, but I notice some unwanted results in my test project.
  1. It processes components that are “Element Hidden”
  2. Processes All categories regardless of V/G settings
  3. Filters set to turn off systems are ignored. Systems with visibility set off were still modified.
Personally I was thinking, yay here’s a node that can help aide selections on my scripts, but it seems like it should be relabeled “All items on Active Level.”
Try the “Collector.ElementsInView” node from spring nodes. It should follow the view’s visibility settings.
Perfect, worked as advertised! Thank you for the tip!
