Hi all, is here anyone who can help or show any example of superelevation setting?
I’m struggling with adding superelevation data in correct order to correct curves. I do not know why is superelevation data added sometimes to curve 1 instead of curve 2. I attached also Civil3DToolkit log file, but in my opinion there is problem with my understanding how to set this.
Autodesk_Civil3DToolkit.txt (161.0 KB)
Hi, here is another simplified example with sample data. The question is still same. How to add superelevation data to curves. Thank you for any help in advance.
I used Autodesk sample file
Pipe Networks-3C so everybody has access to it.
Pipe Networks-3C.dwg (1.7 MB)
Dynamo graph is attached.
D4C3D_superelevation_test_01.dyn (25.6 KB)
Sorry, I don’t know a solution for your problem, but I1m curious what is the name of the package, that you use.
Thanks. I had that, but I didn’t find the exact node with search bar previously. Now I found it manually.
