Im looking for a package or node that returns constrains similiar to the reveal constraints tool native in Revit. Ideally I would like to be able to remove constraints as part of model cleanup. Im not sure if these functions are available in the API though. Thanks!
@J_Sanford try this one, it will remove the EQ dimensions constraints in a project environment:
clr.AddReference('RevitAPI')
dims = IN[0]
if isinstance(dims,list): dims = UnwrapElement(dims)
else: dims = [UnwrapElement(dims)]
nDims = []
#filter multisegments dimensions
dims = [dim for dim in dims if dim.NumberOfSegments > 0]
for dim in dims:
#filter only EQ dimensions
if dim.LookupParameter("Equality Display").AsValueString() == "Equality Text":
#set Equality Display parameter to Value
dim.AreSegmentsEqual = True
#fetch affected dimensions only
nDims.append(dim)
OUT = nDims
Dope thanks!
