Here you can see what each lists contain
When I use the script which is provided in the solution the 3rd list isn’t inserted in the two lists provided , I want the third list to be also added/divided into the two sub-list , I don’t know if you got what I mean
The approach that I am trying to do here is so that I can have separate rectangles by joining the upper lines separately with rectangle filling lines and the downward lines
try this?
alignment = IN[0]
edge = IN[1]
curve = IN[2]
result = []
for i in range(len(alignment)):
temp = [alignment[i], edge[i], edge[i+1], curve[i]]
result.append(temp)
OUT = result
I cannot say thank you enough , saved my life , I am really grateful
Again a lot of thanks
