Detail Number comes from Location on Sheet(A1, B2, etc)
Aloha all. Quick update. I have gotten super busy so I’ll add a quick explanation and share what I have currently. I am still working on it so its still kinda messy. Works best in Player.
First and foremost, this graph works with Revit 2022. For use on the 2020 version, the viewport location box outlines (Origin) are different and require minimal tweaks.
SETUP:
Required Packages: Archi-lab.net & Rhythm.
Titleblock:
Project Units: mm
Where I work, we have the grid as “1-20” wide and “A-P” Tall. You will need to create and label dimensions as shown in the image below. Make sure to match the labels as your graph calls to them specifically.
When you have your titleblock updated with the labels, load it into a project.
Before running the graph, change your project units (Length) to mm.
AlphaNumeric.dyn (181.2 KB)
