I used ‘Block.ByName’ and created the blocks. The problem is that I can’t create objects inside them. Your second option is exactly what I want: just move the objects into the created block. I found a topic where you used a node that transforms geometry into blocks, and it seems to be exactly what I need, but it looks like this node is no longer available.
Related topics
| Create block reference from object but don't want inserted, just created for use later | 3 | 152 | January 25, 2025 | |
| How to create a new Block Definition? | 12 | 2031 | November 13, 2021 | |
| Is there a way to create block definitions from Civilobjects? | 1 | 183 | February 25, 2025 | |
| Combine Polyline as Block in civil 3d Dynamo | 3 | 302 | May 24, 2023 | |
| Missing node “BlockReferenceExtensions.ByGeometry” in Civil3DToolkit for Civil 3D 2026? | 2 | 144 | November 19, 2025 |
