Unfortunately doesn’t work.
I found this thread https://forum.dynamobim.com/t/create-type-parameters-in-dynamo/3200/4 and I was able to re-type the code so it works if I want to add ONE Type parameter. But if I need to add a list of Instance parameters (defined by string) it doesn’t work. I need to change the code but I am not familiar with Python
If you somehow could help me with that…
clr.AddReference(“RevitServices”)
clr.AddReference(“RevitAPI”)
par_name = IN[0]
par_type = ParameterType.YesNo
par_grp = BuiltInParameterGroup.PG_VISIBILITY
OUT = doc.FamilyManager.AddParameter(par_name, par_grp, par_type, False)
