# ZT node error: Dictionary.ValueAtKey expects argument type
**URL:** <https://forum.dynamobim.com/t/zt-node-error-dictionary-valueatkey-expects-argument-type/30178>\
**Category:** Developers\
**Tags:** zerotouch\
**Created:** [January 1, 2019, 1:59pm UTC](https://forum.dynamobim.com/t/zt-node-error-dictionary-valueatkey-expects-argument-type/30178 "2019-01-01T13:59:33Z")\
**Showing post:** 2
**Author:** ![Thomas\_Mahon](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/thomas_mahon/32/64209_2.png) [@Thomas\_Mahon](https://forum.dynamobim.com/u/Thomas_Mahon)\
**Post date:** [January 1, 2019, 2:23pm UTC](https://forum.dynamobim.com/t/zt-node-error-dictionary-valueatkey-expects-argument-type/30178/2 "2019-01-01T14:23:22Z")
Only use a dictionary/multi output port node if you have multiple outputs rather than using them as a hack. Dynamo reroutes dictionary values to the ports and single keys cause exceptions. Plus you’re going to end up adding another rank to your list unnecessarily and force users into circumventing the problem you’ll create using lacing aimlessly. If you correct it in the future (by reverting to a list as your return type), [you’ll break every graph where it’s used](https://forum.dynamobim.com/t/rhythm-2018-12-4-dimensions-segments-node-acting-funny/29689) so always get the basics right from the outset. Use the `return` statement followed by the object you want to return (not a new dictionary obviously!) for single output ports.
If you want to rename the output port add XML documentation to your project. Once added, type a triple slash above your method to add the tags. You’ll see a tag called `<returns></returns>` - insert the name property and recompile. Eg `<returns name = “something”></returns>`
_[View the full topic](https://forum.dynamobim.com/t/zt-node-error-dictionary-valueatkey-expects-argument-type/30178)._
