Got a rather simple Zero Touch Node, which basically generates a point triangle (I left the more complex parts out, as they are not used in this example anyways). First, this is the code:
public class Triangle
/// <summary>
/// All three Points that make up the Triangle. Tip is index 2
/// </summary>
public D.Point[] Points { get; private set; }
public D.Vector Normal { get; private set; }
private Triangle(D.Plane BasePlane, double Diameter)
D.Circle c = D.Circle.ByCenterPointRadiusNormal(BasePlane.Origin, Diameter, BasePlane.Normal);
D.Polygon p = D.Polygon.RegularPolygon(c, 3);
this.Points = p.Corners();
this.Normal = BasePlane.Normal;
public static Triangle ByBasePlane(D.Plane BasePlane, double Diameter = 1.0)
return new Triangle(BasePlane, Diameter);
Now, the node works fine, and shows as it should in Dynamo 2.8:
Clearly I must be doing something wrong code-wise, but I can’t make out what. Any clues highly appreciated!
when you disconnect the node, I think the points you return are disposed.
Your getter should return new points.
Don’t cache geometry that you later return into the graph.
I think we may have an attribute you can use to mark geometry as a long lived reference if you want to keep it safe from the DS garbage collector if you really need to do this for some reason.
@Aparajit_Pratap FYI.
@aliasguru I think Mike is correct. The points and normal are getting disposed and when the getter is invoked again, there is nothing to return. Could you try using the [KeepReference] attribute on Points and Normal properties.
Alternatively as @Michael_Kirschner2 mentions you’ll need to create new points and normal in the getters.
Hi @Michael_Kirschner2 and @Aparajit_Pratap thanks for both of your replies. Seems like your advise that the Points might be disposed of after disconnection is spot on correct. I could not get the [KeepReference]
attribute to work, the IDE complained about this parameter only being valid on Parameter declarations, so the following produces C# error CS0592:
[R.KeepReference]
But, by simply defining a private property to hold the Point Array, and returning that from the Points property, the node behaves correctly. So this down low works:
private D.Point[] points;
/// <summary>
/// </summary>
public D.Point[] Points { get { return this.points; } }
whereas the following syntax shows the described behavior from the question:
worth noting that the same trick does not work with the Normal
parameter, only with the Points[]
Array.
Just marked @Michael_Kirschner2 initial post as the solution, this is the only method that consistently works.
when you return your points or your normal try translating them by (0,0,0) to make a copy.
