# Wrong rebar Hook orientation REVIT API
**URL:** <https://forum.dynamobim.com/t/wrong-rebar-hook-orientation-revit-api/89094>\
**Category:** Developers\
**Tags:** python, dynamo\
**Created:** [April 30, 2023, 10:08am UTC](https://forum.dynamobim.com/t/wrong-rebar-hook-orientation-revit-api/89094 "2023-04-30T10:08:25Z")\
**Showing post:** 31
**Author:** ![c.poupin](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/c.poupin/32/89152_2.png) [@c.poupin](https://forum.dynamobim.com/u/c.poupin)\
**Post date:** [May 4, 2023, 8:26am UTC](https://forum.dynamobim.com/t/wrong-rebar-hook-orientation-revit-api/89094/31 "2023-05-04T08:26:02Z")
after some test here is an approach by selecting a face, I could not explain everything because the structure is really out of my area of ​​​​expertise, and this part of the API seems really very complex to understand
 ![image](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/8/c/8c8098eaf1cd297d4c3d6417a7a9f2fa71a1079a.png)
![test rebar on beam](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/d/b/db8890775aca55e078d6642ba01bdf777dd6c9b3.gif)
```auto
import math
from System.Collections.Generic import IList, List
from Autodesk.Revit.UI.Selection import *
Btm_bar_type = UnwrapElement(IN[0])
Top_bar_type = UnwrapElement(IN[1])
bar_Hook_type = UnwrapElement(IN[2])
cover = IN[3]/0.3048
spacing = 0.10/0.3048
TaskDialog.Show("Selection", "Pick a Face")
ref = uidoc.Selection.PickObject(ObjectType.Face, "Pick a Face")
# get Face Geometry
sel_elem = doc.GetElement(ref)
tf1 = sel_elem.GetTotalTransform()
face = sel_elem.GetGeometryObjectFromReference(ref)
# get the instance of Face Normal (Transformed)
faceNormal = tf1.OfVector(face.FaceNormal)
#beam_width
width = doc.GetElement(sel_elem.GetTypeId()).LookupParameter("b").AsDouble()
# get beam direction
beam_direction = sel_elem.Location.Curve.Direction
# create an transfrom for onternal offset
tf2 = DB.Transform.CreateTranslation(face.FaceNormal.Negate() * 0.1)
curveLoop = face.GetEdgesAsCurveLoops()[0]
# move curveloop inside the beam
# compute a transformation translation
offset_curvloop = DB.CurveLoop.CreateViaOffset(curveLoop, -0.1, face.FaceNormal)
# apply the fully transform to get the instance of Geometry
offset_curvloop = DB.CurveLoop.CreateViaTransform(offset_curvloop, tf1.Multiply(tf2))
# get top and bottom curves
curvesorted = sorted(offset_curvloop, key = lambda x : x.Length)
bottomLine, topLine = sorted(curvesorted[2:], key = lambda x : x.GetEndPoint(0))
t = Transaction(doc, "Script Rebar")
t.Start()
# compute the normal for Rebar
if faceNormal.CrossProduct(beam_direction).IsAlmostEqualTo(XYZ(0,0,-1)):
	normT = topLine.Direction.CrossProduct(XYZ.BasisZ)
	normB = topLine.Direction.CrossProduct(XYZ.BasisZ)
	normT = topLine.Direction.CrossProduct(XYZ.BasisZ).Negate()
	normB = topLine.Direction.CrossProduct(XYZ.BasisZ).Negate()
Top_rebar = Rebar.CreateFromCurves(doc,
								RebarStyle.Standard,
								Btm_bar_type,
								bar_Hook_type,
								bar_Hook_type,
								sel_elem,
								normT,
								List[DB.Curve]([topLine]),
								RebarHookOrientation.Left,
								RebarHookOrientation.Right,
								True,
								True)
Top_rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(math.ceil((width-2*cover)/spacing), width-2*cover, True, True, True)
Btm_rebar = Rebar.CreateFromCurves(doc,
								Btm_bar_type,
								bar_Hook_type,
								bar_Hook_type,
								sel_elem,
								normB,
								List[DB.Curve]([bottomLine]),
								True,
								True)
Btm_rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(math.ceil((width-2*cover)/spacing), width-2*cover, True, True, True)
t.Commit()
t.Dispose()
OUT = sel_elem, face, bottomLine.ToProtoType(), topLine.ToProtoType()
_[View the full topic](https://forum.dynamobim.com/t/wrong-rebar-hook-orientation-revit-api/89094)._
