Hey all
I’m bit confused on why my definition is not working (likely an obvious reason)
I created a fairly large definition in Dynamo v1.3 to run in Revit 2017 for Room Data Sheet automation and it worked perfectly. Unfortunately the person i was making it for told me they were using the most up to date version of Dynamo, but was actually still on like 0.9 (yay) I had to spend a bit of time backwards engineering it to work on 0.9 and 1.2.1, once i did, it just seems to bug out and give me a “The virtual server that dynamo uses isnt working properly” error. This happened on a few machines so im assuming it was the definition.
Anyway. Ive attached a section of the definition. This section takes 6 parameter values from the rooms within the project and feeds them into 6 shared parameters to be used for Room data sheets (room number, GUID, volume etc.) The definition seems to always miss out one of the parameters and just feeds back a “null” value in the last node and i cannot figure out why.
any help is appreciatedSetRevitValues.dyn (13.1 KB)
