Window Heat Gains Values
#1
I know the values for the windows in Vasari are all based on ASHRAE data from the fundementals book. Is there a way to import more window types or is there a way to change the u value or the shgc?
#2
How about an interface to LBNL's Window 6 ?
#3
Hi Clayton,
In the Vasari UI, you can only set glazing to the values listed here http://wikihelp.autodesk.com/Vasari/enu/TP21/Help/0519-Analyze_519/0618-Conceptu618/0623-Energy_S623/0627-Conceptu627 However, you can access more window types by logging onto Green Building Studio and then re-run your simulations. Hope that helps,
Lilli
