although i provided positive values in the inputs of multipleInputForm++ node, and it is showing positive values in the list as well. but when i plug these into sequence node, it tells me these values are negative!! why is this happening? what kind of output is coming from multipleInputForm++ node?
I think the problem is not with negative or positive, but if it’s really an integer. It’s possible that it’s a float number. You can convert it to integer, just type this to a code block: x:int
put this code block just before the sequence node.
Do not add spaces around the semicolon, just simply x:int
Can you check the type of the output of first item with object.type node? before and after the int conversion? I think my assumption that it’s a float was wrong, and it’s a string.
- If the type is System.String, use the String.ToNumber node to convert it to number.
- I just checked and the sequence node works with non integers, so you don’t need a
x:int
Yeah man, all the outputs were strings (checked by object.type)
And i converted them to numbers using string to number node!
Thanks alot for sparing time for me. You are the best
