Why are all category Ids the same number?
should they not have a uniqueId ?
# Code unterhalb dieser Linie platzieren
_allCats = doc.Settings.Categories
_Name = []
_Id = []
for n in _allCats:
	_Name.append(n.Name)
for i in _allCats:
	_Id.append(n.Id)
# Weisen Sie Ihre Ausgabe der OUT-Variablen zu.
OUT = _allCats, _Name, _Id
KR
Andreas
Can you try in the same loop?
for i in _allCats:
    _Name.append(i.Name)
    _Id.append(i.Id)
hello, at the end of the processing of the 1st loop your variable n is the last category
when you go to the second loop you increment on i but you don’t use it, so the n sent is always the same because the processing of the 1st loop is already done.
you put a print(n) in the 1st loop and a print(n) between the 2 loops and you look at the console
Cordially
christian.stan
