I am using preinstalled Dynamo 2.6.1.
Which dynamo can i use officaly in the latest version? for Revit 2021 and 2022
KR
Andreas
KR
Andreas
Unless you are a custom developer trying out new features I would suggest updating your Revit build via the Autodesk app to latest, then using the Dynamo build it contains by default. This has been the case since Revit 2020.
You mean it is part of Hotfix?
Yes the Revit updates released by Autodesk will also upgrade Dynamo to the latest build for general use. Daily builds and upcoming builds can be installed separately, but it’s only necessary if you need to anticipate how Dynamo will work in future or need access to new features early. Generally that’s developers only.
I am just someone who try to establish dynamo workflows in projects. I am happy when scripts run stable! Thank you for the info!
Yes in that case the current supported build is best to use for sure! You’re welcome
