Hello i got a stange question
My script is exporting a Description field, that i want to import via a excelfil > txt file > keynote text
Problem is when i export my multiline description parameter into excel > converting the file to txt and reloading Keynote. my return is only a single line parameter
Its seems like the data in collum b is set properly, but its only feeds revit the first line
If i delete the exported data and rewrite the same data is works? and idea:D
