Hi.
I used If node and ScopeIf+ node (from Clockwork) and got different results.
I’ve searched about this but I have no clue.
(if the point list of Element.Location+ is empty, the result Tag Location Point.)
Can anyone explain it easily?
Hi.
The clockwork github page defines the clockwork version as a more robust version of the core ScopeIf node (which can also deal with levels)
https://github.com/andydandy74/ClockworkForDynamo/wiki/1.x-Node-Documentation
The Dynamo Dictionary describes ScopeIf as helping deal with two lists of different lengths.
http://dictionary.dynamobim.com/#/Core/Logic/Action/ScopeIf
I presume (others may give a better solution!) that feeding a single ‘empty list’ into ‘false’ and multiple ‘location points’ into ‘true’ is the problem…
Hope that helps,
Mark
