I have collected the link room data and filter it according to my requirement. Now not able to add Finished wall as per the room data provided. I have added two parameters in the room, “Wall Name” & " Ceiling Height", Wall name will the exact same as the finish wall name and the ceiling height should be the wall height. Please find the below image:
so you want to add to your wall room-information(linked) ?
Want to add a finish wall inside the room.
open the file where the rooms are , grap the data from the wall…
bimorphnodes and datashapes have good packages for handle that suff.
I am using below node to create the wall in my live file, this node is working fine if my room data comes from live file, as the room data and the arch wall both comes from linked file may be the node is not working.
