How can i play a sound at the end of my script…
Personally I use the following python snip:
import winsound
duration = 2500 # millisecond
freq = 440 # Hz
winsound.Beep(freq, duration)
#Assign your output to the OUT variable.
OUT = "Success"
Setting a simple “dummy”-input from the end of your graph will delay the sound till that portion of the graph have run.
and if i want to run an mp3…
Apart from writing a C# script with the song I do not believe that is possible using the IronPython shell.
May I ask why you require the ability to play a mp3 on completion?
My best guess … he’s proud of his script
we have very complex drawings, printing drawings can take up to 40min to complete…i made a script that handles the printing, but i wan’t an audio file to make notice that the printing is done.
and running an mp3 is then just fun…
but i must be possible to just run a file…
You can make your computer talk giving the user a talking heads-up
clr.AddReference('System.Speech')
from System.Speech.Synthesis import SpeechSynthesizer
speechSynthesizer = SpeechSynthesizer()
speechSynthesizer.SpeakAsync("Your graph have now finished making awesome drawings")
Hi Arno,
This ought to open any file with the default application:
sys.path.append(pyt_path)
import os
OUT = os.startfile(r"C:\Taco\music\De Kift - Bal\01 Bal.mp3")
You can use SoundPlayer to play .wav files.
from System.Media import SoundPlayer
sp = SoundPlayer()
sp.SoundLocation = “C:\my.wav”
sp.Play()
And here is something to play if the Dynamo graph needs help
import winsound
import time
f1 = 800
f2 = 800
d1 = 110
d2 = 210
s1 = 0.3
s2 = 1.2
for i in range(0,4):
winsound.Beep(f1, d1)
time.sleep(s1)
winsound.Beep(f2, d2)
time.sleep(s1)
time.sleep(s2)
OUT = "Success"
Ah, good old winsound… My favourite…
