Just came across this with the built in Wall.ByFace node. It classifies the input “locationLine” as a string?? this seems wrong, and it keeps throwing errors when I input a curve into this because it is expecting a string. Am I missing something here?
Don’t know exactly how it works, but I think it is the way you build your wall vis-à-vis of the line you hand to Revit. I don’t know how it is in English, but it is something like :
- The line I give to Revit is the center of the wall
- The line I give to Revit is the exterior line of the wall
- etc.
It is the first parameter that appears when you click on a wall (sorry again, it is in French).
Hope this helps
Ah that makes sense. I thought it was referencing the actual line at the bottom of the wall or something. Thanks!
