Morning all,
i thought that the endLevel was the equivalent of the top constraint, was i wrong?
Just use Element.SetParameterByName just after Wall.ByCurveAndLevels to set the “Top Constraint” parameter with the Level.LevelAbove values. It should not modify the resulting walls geometry.
That’s what i’m doing but i wonder why it’s not working with the native node
Very quick answer, to be validated: It could be because setting the height is the only option available through the API:
http://www.revitapidocs.com/2017/d0678575-843b-42ea-c91d-c94b13d7dd4f.htm
Create(Document, Curve, ElementId, ElementId, Double, Double, Boolean, Boolean)
Creates a new rectangular profile wall within the project using the specified wall type, height, and offset.
If it’s the case, the next series of node should be bundle in it (SetParameter)… my 2 cents
Yeah, it looks like the Top Constraint cannot be set during the creation of the wall.
@Daniel_Hurtubise this process could very easily be combined into a custom node or a codeblock.
We agree Nick. The OOTB node should default to that… looks like it’s been dumped in there quickly
Cheers
