I am trying to enable and disable the Volume Computations in a Revit project. I found something on the Building Coder but I cannot find anything in the API. The code also seems different than most of the code I have seen from the API. Has anyone accomplished this or have any more information?
clr.AddReference("RevitAPI")
results = []
settings = AreaVolumeSettings.GetAreaVolumeSettings(doc)
try:
settings.ComputeVolumes = True
results.append(True)
except:
results.append(False)
OUT = results
