I cant rename my views, why? Revit says the names are already there, but it cant be! it is a simple get and set. My strings(values) are correct.
When i do it by hand - manual! it works!
or need i a other statement?
i tested to at “_” than it works, but the naming is wrong, so whats the issue, here?
KR
Andreas
Hi @Draxl_Andreas …could it help to give a temp name before you give the right name …
i did it this way… …by the way my manage warning topic is still under progress
Did you check the warning to see which view(s) were problematic? This can be pretty common with mass updates.
i went true it. the weard thing was, i edit it manualy and it worked.
i ignored this issue and i went to the next package of views and it worked.
