i am testing if C++ comments work in designscript?
But does this someone using it?
! #means not in C++
can i say something like not empty not null, not int 1, …
Can i fill a string value with “s{ }” export to ifc and it appears " " in a viewer? (could be it is not for dynamo-forum
KR
Andreas
is also ‘not’ in design script - quite a few mathematical syntax’s align in many languages.
s{}
won’t allow you to define a string directly; that is only done via the quotation marks method, or by adding a string to something else. I have previously manipulated IFCs in this way, but the exact method to do so will depend on your task and data set.
