Hi experts
I am trying to update an outdated node but i am quite new and is not trained in using the language.
I already found a solution for the flatten but i cannot figure out what to change the inputs to
Hi experts
Welcome @michelFTJKX
Have a quick look in the primer here for a rundown on custom nodes.
https://primer.dynamobim.org/10_Custom-Nodes/10-1_Introduction.html
For a quick fix, change the following.
Views - > InputViews
View Template Name - > ViewTemplateNames
This will force the inputs to use custom variables defined by these names and not the Types/Classes that are causing the issue. (which expect more formatting, per the primer doc)
I will also add that the output will probably need to be named “views” all lower case or “OutputViews”
Eg View(s) → OutputViews
