Hello there,
I’m trying to set door handing with archi-lab node and it is working fine but it forces “group fix” and/or ungroup. Is there a workaround for this?
Hello there,
You are trying to give 2 of the same group instances different parameters?
The parameters would be the same in the same groups - the problem is that I can’t edit the group if there are more than once instance of such.
Can you upload the graph you currently have?
Its solved?
If you need further help pls also upload a dummy project
Its easyer to solve the question when having the same files available.
Yep it looks like it is. I had to add some little tweaks (like excluding Design Options) but it looks like it’s working!
