im considering is it possible to write a code set and embeded it into dnamo bone. so we may track the syntax errors or unresolved nodes in an other window… so we may download the correct library or find the problem source
this is not it but each time i found an aswer to any of my questions i realise that dynamo studio and dynamo revit uses different nodes i dont know why but when you try to open a node that need translation.dll then dynstudio lunches it, so “unresolved” error got its own issues like other syntax errors…
so problem solved but the script is so nice this is exatly what i need to chase anything on parameters i guess…
