Hi
Does anyone know of a way that shadows can be enabled/disabled per view? I can set the sun and shadow settings but now need to find a way to turn them on in the view. I can’t see any property under Snoop…
Hi
from what i know, there isnt a way to do so directly. But a workaround can be achieve via applying view template properties to that view with shadow on or off. i believe you can incorporate all settings into a viewtemplate and apply it to the view
Thanks. But you can’t retrieve 3D view templates correct due to API limitations?
you can. its still there. just that the name isnt readable, so you might need to take note of its ID instead and work with that
