I want to turn off levels from views from different documents at once. Can anyone please have a solution??
Any node that doesn’t use a document input is assumed to run on the active document. You can probably take the SetCategoryVisibility
“apart” and change the python code to accept a document input.
Hello , not really sure what you want, but if you will hide all levels from link and keep you own i would suggest to create a filter and make sure you own levels doesnt have the same family name as the links…and set the filter to not contain…Hope i get it right
