I am unable to open my script! in 1.3.2.
I worked already
I am glad about any advise
I worked already
hi,
try to open new dynamo and get the Turn into list node, then Right Click, Edit in Custom Node, then save it as in the place that the error message give, i think it should work
Can you post your dyn?
I solved it, i did a rebuild of the script! in was the node “door.rooms” it was routed to 0.6. dynamo, so i replaced it by 1.3 clockwork and than it worked! it was realy tricky!
The error message could be more related to the nodes! some warnings are realy cryptic!
