I try to get the part of the quboid thats under the roof solid. (Try to paint the wanted solid in red;)
I don’t need the part of the quboid that’s over the roof.
How i can do this? Any idea? 17_04_08_Forum_Trim2.rvt (1.1 MB) 17_04_08_Forum_Trim.dyn (25.4 KB)
I need the part under the roof and the cuboid together. This needs to be a solid, so i can get the volume of it.
If u translate your blue roof u will see it is empty.
Kulkul, thx for help. But your solution has still the same hight. This means that the roof is trimed by the cuboid and not the other way round. And the roof is hollow which i don’t want.
Yeah this would be good.
The solid musst fullfill these characteristics:
-a full solid for volume calculation
-solid without the roof solid, but with the room/space under the roof as a solid
Kulkul the note difference does what i want, but with one problem…the upper and the lower part of the cuboid are saved in one solid. Is there a way to separate them?
This is an option Dimitar but not for me, because the room below the roof is not filling the hole space and this because of law regulations in my country. .
I am having a similar problem i am trying to use a solid to trim another solid but i cant find a way aound it
I want to cut the top part of the pipes that are marked in red
