Transferring Points from Recap to Revit
Hi everybody,
I have a model including 3D points in the Recap software and intend to convert them to an excel file and then insert them to the Revit, but I encounter some problems in the first section, which solution do you suggest to me?
any help would be appreciated.
Screenshot%20(108)
Thank you for your response.
I need to have the points separately, however when I insert the points through the recap to the Revit directly, the Revit does not distinguish the points and recognize the model as a whole object.
I would really appreciate if you could please suggest me a method for converting Recap points into an Excel file.
