Hi, i am new in this tool; but i want to make the next exercise:
To obtain the thickness of the steel sheet, in base of the width of the duct and his system type.
Example:
If System Type is high velocity and the width is:
< or = 12" caliber 26
(>12") OR (< or = 30" ) caliber 24
If System Type is low velocity and the width is:
< or = 18" caliber 24
(>18") OR (< or = 48" ) caliber 22
This with each range of width of duct and velocity.
Hi this is definitely achievable with Dynamo. I am no MEP expert but you could first group your ducts according to their flow, extract the width parameter and finally give the formula node a try? if(x<=12,opt1,if(x<=18,opt2,opt3))
thank you, so much, but how i have to structure my formula, if i want to do this:
if (system type is SystemX and width is <= 12, OPT1, if (system type is SystemX and width is = 14 o <=30,OPT2, if (system type is SystemY and width is <= 18,OPT3)))
what do you think i don´t know how make the formula in Dynamo.
Maybe someone more familiar with MEP ducting can pitch in, but if you need to provide different options for each type, it might be simpler to split your ducts into types and then perform the necessary actions for that specific type:
