The problem that I have here is creating the clear box based on the doors in different angles (Different direction of wall in north, south and east and width)… I used the Facing.orientation and set.rotation nodes to adjust the family based on the wall direction & Angles ( North, South east west) side of the building. I don’t know why the angles of the doors/ walls is not be adjusted to the created clear box in desire direction. Any Thoughts?
I used this nodes to get the adjusted angle as bellow:
Hello…you can try this here…isnt it the same question you already had asked??
open.dyn (43.9 KB)
Thank you so much but this is not applicable for my application. I have a problem just in vector rotate and facing rotation. I do not want to scale or loft the geometry. As you see on my screen shots, I want to block box be adjusted with he same direction of wall.
Regarding to your question, no, I asked in the following of my previous problem with different subject. Then I posted it separately at the same time.
Allright…you could try get rotation instead of facing orientation…good luck
Thank you so much. The Get.Rotation node solved my problem.
