Maybe Dynamo isn’t the right tool for this job but i hope it is!
I have modeled a Resin panel that has a laser cut pattern cut out of it. It is in compression on two metal rods on the floor and laterally supported with two metal rods on the ceiling. Is there a way in Dynamo to test the strength of the material at 3/4" thick and 1" thick as well as test the compression strength of the connections? If compression isn’t proper for this type of screen could I additionally test suspending it partially in tension and partially in compression?
Cheers!
