I am trying to create a node similar to the gh node “Point in Brep”, where I test if a point is inside a closed polysurface. Ideally this would work with 2D arrays of points, flattened points or 3d arrays of points (list,list,items)—ie the greater good. But I will settle for now on a 2D array (what works for now).
I’m 90% there, but I’m stuck on 2 points: (starting with the second and easiest first)
Q2: Can/How would I us replication guides to replace what a list.map of a list.map of a chop would do? In other words, I want put every item in a 3d array of points into its own list…
Q1: I’ve been able to sort a list of flattened and then chopped (grafted) points (each point in its own list) by a flattened list boolean values as seen below. However, this destroys the data structure which will be critical how I am planning to use this operation
Excuse my poor use of replication guides… I’m still wrapping my head around the concept.
Any ides?
isinsidesolid.v1 (in daily build 1.0.0.276)
