System Configuration Error Revit 2022
I’m pretty new to Dynamo, but getting better.
We are a consultant and need to work in any version of Revit asked of us. We currently have projects back to Revit 2022. So, I try to work in an older version of Revit, so things will work going forward.
I am currently getting a system configuration error in Revit 2022. Dynamo works in all versions of Revit from 2023-2027.
Error shown below.
If you havent already disable all addins and see if it fixes it, then progressively load them back to find which one if so.
2022 is now outside the 4 years apart support window so i suspect if it is dynamo itself a fix would be unlikely. We have projects ‘stuck’ in 21/22 still so know the pain.
On that note we’re assessing how to escape them as, incoming in november:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Cloud-Model-access-for-older-Revit-versions.html
2022 will be locked off in ACC when 2028 comes out. Not that far away. I expect this to tank with users, but afaik autodesk is commiting to this.
It’s been 3 months so I suppose I should post this yet again: Zero Day Initiative — Crafting a Full Exploit RCE from a Crash in Autodesk Revit RFA File Parsing
TLDR: unsupported builds from 2022 and prior need to only be on machines without internet access or you risk allowing execution of code remotely by just loading in Revit files. The only protection is to get into a supported build.
