I started this definition shown below. But I am not getting it to work.
Basically, I have one divided surface inside a mass. I am trying to switch the divided surface type from “Rectangular” to “Octagon” pattern type.
Hi m.rijsmus -
I used Family Type and selected a basic rectangular curtain panel pattern base but I am still not getting the result. For example, it is not:
@m.rijsmus great job! Just a small improvement: you can use the node IndexOf to automatically retrieve the index you need.
For example, if you want to run the script from DynamoPlayer, it might be useful to just type the name of the wanted pattern (in this case Octagon).
You are right.
I think this was a script that was a chalange to solve, never looked further.
You can do this (changing the pattern) with two clicks in Revit itself, so never i thought of doing it in Dynamo, let alone the Player.
The writing of the script takes longer then actually doing it in Revit, so why write it?
