Hello
Is there a way to swap the names here:
for example: Instead of “Section -02Level 1” i want it to show “level1 Section -02”
Hello
some thing like that, example i convert to Section-Level01-02 ,…
def tolist(obj1):
if hasattr(obj1,'__iter__') : return obj1
else : return [obj1]
data = tolist(IN[0])
def ChangeStrPos(string):
lst= string.split(" ")
s,s2,s3 = [""]*3
for i in lst:
if i.find("Level") != -1:
for j in i:
if j.isdigit():
s3 += j
else: s2 += j
print(s3)
s += s2 +s3 + " "
else: s +=i + " "
return s
result = [ChangeStrPos(i) for i in data]
OUT = result
I think you just need to flip the X input into the Y, and the Y input into the X.
