I am attempting to swap out 2d components that have a dimension parameter with 2d line based components. I started with just one and hopefully would be able to figure out how to do a whole project swap. I can extract the start point and end point as well as direction of the 2d component but cant seem to place the 2d line based component.
Thanks!
Hello William,
Cant you use modellines for the job?
Then i suggest the following node:
-Vincent
Vincent,
I am unsure how this helps me? I tried turning the reference curve into a model line, it still will not create the 2d Line Based Component.
Thanks,
WIlliam
I thought this might help but unfortunately it doesn´t. Is it a problem to see the lines in 3D also? I’m not sure how the clockwork node works… sorry
Was anyone able to figure it out?
Thanks,
William
