Suppress an operation upon another operation in dynamo for revit
Hello
I am having a small issue that I had been trying to solve for a couple of days. * I am trying to
Suppress an operation upon another operation in dynamo for revit.
  • I had used “wait for” node in crumple, and some similar nodes with no point
  • Same issue remains
I would appreciate it if you can advise
Seems like the issue is with the join geometry node, not the waitfor
True, but the I think if “wait for” were working properly, “Join geometry” would have worked fine. I guess
You have the waifor on the wrong side, the data out of the wait for should be in your join geometry and the data in to the wait for should be the data currently going into the join geometry. This way it waits for the data before it enters the join geometry node.
Have you tried it like this?
well, I did after your advice it responds with some data (which is better than before) but still the elements do not join. No idea why is that happening
Post a screen grab showing the error.
I got it!! understood the idea and done it. The join geometry node is one of the problems by the way… Thanks guys a lot
I appreciate it
