String to Value
Hi all,
Can I get bridge node String to Value or equivalent to it like String to Number?
@Ali.almurshed
yes you can
1
-biboy
Yes, I know this node. But I need one like it I need String to Value node if any!
@Ali.almurshed what do you mean value?
Value in set parameter by value name node
You should be able to plug the value directly into the SetParameterByValueName node’s value input as long as the object type of the value matches the storage type of the parameter (I.E. if a parameter uses integers, feed the node an integer, not a double or a string).
