I was wondering if there is a way of not running a script if it is a project.
The reason is I want to condense my template (delete some Sheets, rename some and change the classifications) when a project starts. I don’t want it to run if it is a true project because it could mess up so many things
my steps. of a convert a template from a large project to a smaller one
- Delete not used sheets (complete)
- change unused sheets classifications by a sheet parameter (complete) XX- Not Used
- rename the unused sheets changed in the classification (complete) XX-A1.01
- rename the used sheets to fill in the ones moved to not used or deleted. (complete)
some things I thought about is if it doesnt have a filename (starting a new project from a template doesnt have one. the filename appears after you save the file for the first time.,
Any help would be great ThanksCondense a Project.dyn (57.1 KB)
