I am trying to generate a report of file sizes of linked elements. But everythign falls apart at the Springs node FilePath.Size, which returns a null value. Everything up until then reports as expected. I have tried updating springs to get the new /W varient, but thats not working. Any ideas?
You might have to use list levels for it to work properly. It might be using the entire list as the filepath rather than performing the operation on each individual filepath.
When I use levels for the lists, I can change my results, but only in so far as it returns multiple nulls, instead of a single null. I’m really stuck here.
Here’s the bit that is causing me some frustration. I have also tried using the node “Get Loaded RVT Links” from Bakery, in case the script I found in this thread ( DWG Links File Sizes ) wasn’t working.
I realized I had levels on in the RVT section, and removed it, and it works on my test file with a single rvt linked in, So you must be right, I’m just at a loss as to where my list levels are needed/failing when I tinkered with it in the DWG links section.
@cgartland, I don’t know why, but I noticed it was pulling a list form a previous project. restarted dynamo and it works fine, Sorry for the confusion!
