In an attempt to neatly align spotelevations, I’m trying to access the leader location lines.
So roughly:
- select elements
- get location through nodes: gives the insertion point of a spot elevation not the leader / shoulder.
- through python / api I believe this would be the Leader class, which would give access to the elbow.
- my thought is: after getting the location of the elbows, set that location to a common x-value: done.
Accessing it through python gives ‘no attribute Leader’. Which makes sense however … how would I be able to access it?
elements = UnwrapElement(IN[0])
output = []
for element in elements:
new = element.Leader
result = new
output.append(result)
OUT = output
