I would like to use Spell Check option which is available for Text Notes to apply on Multi-Category Tags as well. Is it possible using Dynamo?
Yes. There are a few posts on this already. Have a look around the forum, and check out the FuzzyDyno package.
Note that you need to spell check the parameter values not the tags themselves.
@JacobSmall I have tried searching with FuzzyDyno keyword. But I am unable to find any relevant topic.
If you could help point me towards the post or help paste the solution here.
I have tried with this. Looks complicated. Is there any alternative method for Beginners?
Nope - winds up that performing a spell check is complicated work.
here are 2 other solutions (IronPython or Archilab)
the IronPython solution code (using Interrop)
import sys
import System
clr.AddReference("Microsoft.Office.Interop.Word")
import Microsoft.Office.Interop.Word as Word
clr.AddReference("office")
from Microsoft.Office.Core import *
clr.AddReference("System.Runtime.InteropServices")
import System.Runtime.InteropServices
lstWord = IN[0]
out = []
app = Word.ApplicationClass()
docWord = app.Documents.Add()
# automatically detects the language you are using as you type
languageAutoCheck = app.CheckLanguage
# the language selected for the Microsoft Word user interface
currentUILangInt = app.Language
currentUILanguage = System.Enum.ToObject(MsoLanguageID, currentUILangInt)
# check words
for w in lstWord:
spellingIsCorrect = app.CheckSpelling(w)
if spellingIsCorrect:
out.append(w)
suggestions = [x.Name for x in app.GetSpellingSuggestions(w)]
# get the first suggestion
out.append(suggestions[0])
docWord.Close()
app.Quit()
app = None
OUT = out
pyspellchecker CPython3 package can be also an alternative
Thankyou @c.poupin
I have come to conclusion that spell check isn’t really 100% reliable with correct words. So I would request if you can help me just highlight the misspelt words in the project into say Orange color. Then it would be better to do it manually.
