The Spaces don’t intersect the windows, so i did increase its solid, but the problem that its going to be a solid and i cannot use “Elements in Space” node (Archi-lab_Grimshaw package).
(I could make it work with the bounding box of the solid, but the “BoundingBox.Intersection” node is not working correctly. It intersects elements that are not even in the bounding box)
Question:
Is there a custom node called “Elements in Solid” node outthere?
Just tested. No it does not. However the revit API does allow for the method Space.IsPointInSpace which functions the same way as the room. Look into building some python around the Space method, which you can see the inputs and such for here:
