Hi guys.
I’m looking for help with the node BuildLayout.PlaceDepartments.
I keep getting this error message even after following the tutorials exactly.
I am also having trouble uploading the CSV file here associated with this.
sampleSite.sat (45.7 KB)
26 AUG SPACE PLAN _ SEND_TEST.dyn (88.9 KB)
bedTowerSKPU1.xlsx (11.9 KB)
Add a .txt after the .csv.
Thanks Jacob.
Also I found this worked. Entering the text into a string node.
Hey somewhat new to this. Is it necessary to use a string for the excel data or can one use the read from excel file nodes? I got most of it working but I am stuck at this.
You could use the excel data node as long as you format the data coming from it correctly.
