Two related questions:
A) when I reference curtain panels created by level (all of the same type), they are not organized in sub-lists by level. What is the reason for this and how can it be resolved?
B) After I have manually sorted the panels per level into sub-lists, I have trying to create a checkerboard pattern with ‘List.SortByKey’ where each list is either true or false. (See image a).
Hello!
Maybe this can help you sort your lists by keys.
Thank you for your reply.
I have used List.SortByKeys twice to order my panels (see image B). My questions is: a) why is this necessary when the curtains are already hosted on their specific levels?
Also, I cannot figure out how to make the List.FilterByBoolMask can operated on each sub-list to create a true/false pattern on each level.
They are probably organized by wall. So if you have a multi level spanning walls, that would mean panels are grouped under the wall, but not level.
